Introduzione
This guide shows how to completely take out the motherboard for a total replacement.
Cosa ti serve
Remove the hard drive cover.
Unscrew one 8mm Phillips #00 screw.
Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
Unscrew the one 8mm screw using a Phillips #00.
Using the black spudger, slightly pry up on the tab and gently pull the optical drive away from the laptop in order to remove it.
Un commento
Step#3, You need to remove a total of 13 screws from the bottom of the laptop BEFORE prying the keyboard section off the laptop. See picsĀ https://imgur.com/a/h5d1zJ1
