Salta al contenuto principale
Asus U47VC-DS51 LCD Screen Replacement
Cosa ti serve
  1. Asus U47VC-DS51 LCD Screen Replacement, Keyboard: passo 1, immagine 1 di 2 Asus U47VC-DS51 LCD Screen Replacement, Keyboard: passo 1, immagine 2 di 2
    • Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
    • Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
  2. Asus U47VC-DS51 LCD Screen Replacement: passo 2, immagine 1 di 2 Asus U47VC-DS51 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Using the black spudger, insert its flat end between the crevice where the color changes from grey to black.
    • The keyboard is very tightly secured.
    • Carefully ease the spudger's end along the crevice, going around the entire frame.
    • The back connectors are short, so be careful when lifting.
  3. Asus U47VC-DS51 LCD Screen Replacement: passo 3, immagine 1 di 2 Asus U47VC-DS51 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Lift the keyboard from the front where it is closest to the screen.
    • Disconnect the large and small ZIF connectors attached to the motherboard by flipping the light-colored part of the switch.
  4. Asus U47VC-DS51 LCD Screen Replacement: passo 4, immagine 1 di 2 Asus U47VC-DS51 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the third and last ZIF connector on the motherboard by flipping up the dark-colored part of the switch.
    • Now, the component should come completely free.
  5. Asus U47VC-DS51 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 1
    • Unscrew the two 4mm phillips head #00 screws.
  6. Asus U47VC-DS51 LCD Screen Replacement: passo 6, immagine 1 di 3 Asus U47VC-DS51 LCD Screen Replacement: passo 6, immagine 2 di 3 Asus U47VC-DS51 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Use the black spudger to pry the face plate off.
    • The face plate is attached with adhesive.
    • Gently peel the face plate from the base.
  7. Asus U47VC-DS51 LCD Screen Replacement: passo 7, immagine 1 di 3 Asus U47VC-DS51 LCD Screen Replacement: passo 7, immagine 2 di 3 Asus U47VC-DS51 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Unscrew the four 3mm Phillips head #00 screws holding the screen to the base.
    • When sitting upright, the screen should fall forward from the top.
  8. Asus U47VC-DS51 LCD Screen Replacement: passo 8, immagine 1 di 2 Asus U47VC-DS51 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Unease the yellow connecting tape with the spudger at the bottom of the screen.
    • Pull the connector straight down and it will disconnect fairly easy.
    • The screen should then be free to be removed.
Conclusione
1Commento della guida
Ich weiß nicht warum aber mein Laptop der zeigt mir immer ein blauen Bildschirm an und da steht irgendwas von Software Update bitte helfen sie mir ich will nicht sehr viel Geld ausgeben
Bobenmazue - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 552
