Salta al contenuto principale
Asus Transformer T100 Front Facing Camera Board Replacement
Cosa ti serve
  1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: passo 1, immagine 1 di 2 Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: passo 1, immagine 2 di 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Front Facing Camera Board Replacement: passo 2, immagine 1 di 2 Asus Transformer T100 Front Facing Camera Board Replacement: passo 2, immagine 2 di 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
    Ole Hoppe - Replica
  3. Asus Transformer T100 Front Facing Camera Board Replacement: passo 3, immagine 1 di 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Front Facing Camera Board Replacement: passo 4, immagine 1 di 2 Asus Transformer T100 Front Facing Camera Board Replacement: passo 4, immagine 2 di 2
    • Remove the rear casing.
  5. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: passo 5, immagine 1 di 1
    • The camera board is located in the red square in this image.
  6. Asus Transformer T100 Front Facing Camera Board Replacement: passo 6, immagine 1 di 2 Asus Transformer T100 Front Facing Camera Board Replacement: passo 6, immagine 2 di 2
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  7. Asus Transformer T100 Front Facing Camera Board Replacement: passo 7, immagine 1 di 3 Asus Transformer T100 Front Facing Camera Board Replacement: passo 7, immagine 2 di 3 Asus Transformer T100 Front Facing Camera Board Replacement: passo 7, immagine 3 di 3
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
    These "Connection Apparatuses" are ZIF (Zero Insertion Force) FFC (Flexible Flat Cable) Connectors, and instead of trying to pull/wiggle the ribbon cable out, the side of the Connector with the ribbon going into it, has a gate that will flip up making the ribbon just simply slide out. The ribbons are also easier to reinstall with the gates flipped up as well. You just have to be careful with the gates as to not break the hinges. I will typically use the plastic case opening tool to pry the gate open.
    Wingman - Replica
  8. Asus Transformer T100 Front Facing Camera Board Replacement: passo 8, immagine 1 di 2 Asus Transformer T100 Front Facing Camera Board Replacement: passo 8, immagine 2 di 2
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  9. Asus Transformer T100 Front Facing Camera Board Replacement: passo 9, immagine 1 di 3 Asus Transformer T100 Front Facing Camera Board Replacement: passo 9, immagine 2 di 3 Asus Transformer T100 Front Facing Camera Board Replacement: passo 9, immagine 3 di 3
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
    This port DOES have a clip. It's the white bit on the backside of the port. Flip it up and the connector will slide loose with no force at all.
    blakebowen - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Taylor Pantiga
Membro da: 04/14/14
1.596 Reputazione
6 Guide realizzate
Cal Poly, Team 13-31, Maness Spring 2014 Membro di Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Membri
6 Guide realizzate
Un commento
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,658
