Introduzione
All the buttons on the tablet are located in one corner. They are all controlled by a button module board, which can be removed if desired.
Cosa ti serve
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
Unclip the white connection clip using a pair of tweezers.
Altre 4 persone hanno completato questa guida.
Un commento
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
