Introduzione
Is your Asus Transformer Pad (TF103C) display not doing what it should be? Is the LCD screen black or not working correctly? This guide will walk you through the steps of replacing the LCD screen of the Asus Transformer Pad.
Replacing the screen is complicated, and has more than 25 steps to achieve. Removal of multiple small electronic parts and chips are required to get access to the LCD display.
Remember, punctured batteries can cause dangerous fires, so use caution when handling the battery.
Cosa ti serve
Make sure the power is off.
Insert the plastic opening tool into a crack on side of the tablet.
Carefully pull the tool upwards to and pry open the Transformer pad.
Altre 9 persone hanno completato questa guida.
2 Commenti
I was wondering if you could tell me which ribbon cable connects the screen, and in particular the touch input to the main board. I would guess that it is the one labeled 14010-00190900.
I am having the problem with intermittent touch input failure, and since my device is not on warranty, I thought I might try replacing the ribbon cable.
