Introduzione
Is your Asus Transformer Pad (TF103C) not charging? Does the battery not last very long? This guide will walk you through the steps of replacing the battery of the Asus Transformer Pad.
Replacing the battery is relatively simple. It only takes 5 steps to complete. Very basic tools are required, but can be switched out for more common tools.
Remember, punctured batteries can cause dangerous fires, so use caution when handling the battery.
Strumenti
Ricambi
Make sure the power is off.
Insert the plastic opening tool into a crack on side of the tablet.
Carefully pull the tool upwards to and pry open the Transformer pad.
Altre 5 persone hanno completato questa guida.
4 Commenti
I had problems with the power button and thanks to your detailed explaination I managed to get the things ok
thanks a lot
Paolo
My tab didn't turn on (stuck in booting limbo), didn't want to wait for a month or so till the battery dropped to 0%, so I tried this method instead. Done everything correctly. I'm sure I didn't screw up. Tablet won't start again (not even charging). I'm not sure if is either the faulty battery or the chipset attached to it. Either way, is a crappy tablet, never happened to lose a device so easily after a DIY repair. This would never happened if only Asus did insert reset buttons on their devices (or a soft reset button sequence). Will never buy an Asus tablet again.
Did you plug the new battery wires correctly
red on red and so on the other?
Hi, i changed the battery, but now I have kind of a situation with this. My brand new battery is losing energy pretty fast , until 2%. When this reach 2% I can use the tablet for more than 10h with the screen on, or more. But if I use it for 2 h , in 2% , an then I close the screen for 5 minutes, the tablet shut down , and I can't open it until I put back the charger. Even though I have plenty of juice in the battery. How do I fix this ? Is there a way to recalibrate the software? I already tried to connect and disconnect the battery and charger back to 100. It doesn't work. I reinstalled the latest version of software. Doesn't work. Can anyone help me ?
