Salta al contenuto principale
Asus Transformer Pad Infinity LCD Display Replacement
Cosa ti serve
  1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: passo 1, immagine 1 di 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: passo 1, immagine 2 di 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: passo 1, immagine 3 di 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity LCD Display Replacement: passo 2, immagine 1 di 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity LCD Display Replacement: passo 3, immagine 1 di 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity LCD Display Replacement: passo 4, immagine 1 di 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity LCD Display Replacement: passo 5, immagine 1 di 1
    • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
    • If it doesn’t, make sure you secure it with the screws safely).
Conclusione
Allison Poh
Membro da: 10/20/15
549 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,230
