Salta al contenuto principale
Asus Transformer Pad Infinity Battery Replacement
Cosa ti serve
  1. Asus Transformer Pad Infinity Battery Replacement, Battery: passo 1, immagine 1 di 3 Asus Transformer Pad Infinity Battery Replacement, Battery: passo 1, immagine 2 di 3 Asus Transformer Pad Infinity Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity Battery Replacement: passo 2, immagine 1 di 1
    • Disconnect the battery from the big motherboard.
  3. Asus Transformer Pad Infinity Battery Replacement: passo 3, immagine 1 di 1
    • Unscrew all eight screws connecting the battery to the case.
    • Remove the battery.
  4. Asus Transformer Pad Infinity Battery Replacement: passo 4, immagine 1 di 1
    • Place the new battery in the same spot as the old battery.
    • Screw the eight screws back in place to connect the new battery to the case.
Conclusione
Allison Poh
Membro da: 10/20/15
549 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,899
