Salta al contenuto principale
Asus Transformer Book T100TAR Front Camera Replacement
Cosa ti serve
  1. Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: passo 1, immagine 1 di 2 Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: passo 1, immagine 2 di 2
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Front Camera Replacement: passo 2, immagine 1 di 1
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the spudger along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Front Camera Replacement: passo 3, immagine 1 di 1
    • Take off the rear case
  4. Asus Transformer Book T100TAR Front Camera Replacement: passo 4, immagine 1 di 1
    • Unscrew two 5mm screws from the camera board using a Phillips #0 Screwdriver.
  5. Asus Transformer Book T100TAR Front Camera Replacement: passo 5, immagine 1 di 1
    • Using a plastic opening tool, lift the white tab holding the power button cable, located on the camera board and pull out the cable strip.
  6. Asus Transformer Book T100TAR Front Camera Replacement: passo 6, immagine 1 di 1
    • Also using the plastic opening tool, gently lift up and remove the large black strip connecting the camera board to the motherboard.
  7. Asus Transformer Book T100TAR Front Camera Replacement: passo 7, immagine 1 di 1
    • Remove the camera board.
Conclusione
USF Tampa, Team 6-1, Remmell Fall 2016 Membro di USF Tampa, Team 6-1, Remmell Fall 2016
USFT-REMMELL-F16S6G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 436
