Salta al contenuto principale
Asus Transformer Book T100TAF Motherboard Replacement
Cosa ti serve
  1. Asus Transformer Book T100TAF Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Detach the screen from the keyboard using the silver button and pulling the screen in the upwards direction.
  2. Asus Transformer Book T100TAF Motherboard Replacement: passo 2, immagine 1 di 1
    • Pry the plastic backing off of the tablet using the plastic spudger, releasing all interior clips.
  3. Asus Transformer Book T100TAF Motherboard Replacement: passo 3, immagine 1 di 1
    • Unscrew all the silver screws from the motherboard
    • 3.0 mm (3) silver phillips head
  4. Asus Transformer Book T100TAF Motherboard Replacement: passo 4, immagine 1 di 2 Asus Transformer Book T100TAF Motherboard Replacement: passo 4, immagine 2 di 2
    • Unscrew all the black screws from the motherboard with a PH00 screwdriver
    • 4.5 mm (4) black phillips head
    • 4.5 mm (2) black phillips head
  5. Asus Transformer Book T100TAF Motherboard Replacement: passo 5, immagine 1 di 1
    • Detach the battery cable by steadily pulling it away from the motherboard with angled tweezers.
  6. Asus Transformer Book T100TAF Motherboard Replacement: passo 6, immagine 1 di 1
    • Gently pry the orange ribbon cable that is near the battery cable upwards with tweezers.
  7. Asus Transformer Book T100TAF Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the black strip along the top edge, releasing the two sets of connections.
    • Adhesive may hold this strip to the motherboard.
  8. Asus Transformer Book T100TAF Motherboard Replacement: passo 8, immagine 1 di 1
    • Use tweezers to detach the black and red twisted pair cable from its connection to the motherboard.
  9. Asus Transformer Book T100TAF Motherboard Replacement: passo 9, immagine 1 di 2 Asus Transformer Book T100TAF Motherboard Replacement: passo 9, immagine 2 di 2
    • Detach the two thin black wires by grabbing them with tweezers.
  10. Asus Transformer Book T100TAF Motherboard Replacement: passo 10, immagine 1 di 1
    • With tweezers, gently flip the white clip up that is holding the white ribbon cable down. Pull the base of the white ribbon cable away from the motherboard with tweezers.
  11. Asus Transformer Book T100TAF Motherboard Replacement: passo 11, immagine 1 di 1
    • Disconnect the bottom orange ribbon cable with tweezers by pulling it away from the edge of the device.
  12. Asus Transformer Book T100TAF Motherboard Replacement: passo 12, immagine 1 di 1
    • Verify that cables are no longer attached to the motherboard.
  13. Asus Transformer Book T100TAF Motherboard Replacement: passo 13, immagine 1 di 2 Asus Transformer Book T100TAF Motherboard Replacement: passo 13, immagine 2 di 2
    • Grab the motherboard with two hands, and gently lift it out of the device.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 4-3, Passmore Fall 2016 Membro di USF Tampa, Team 4-3, Passmore Fall 2016
USFT-PASSMORE-F16S4G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,802
