Introduzione
This guide will walk you through the steps to replace a dead or non-working motherboard in an Asus Tablet MeMo Pad 7 ME700C. Make sure you are using the proper tools and exercising caution while opening the back panel to avoid causing damage to the tablet.
Cosa ti serve
Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
Disconnect the microphone plug from the motherboard.
Use the tweezers to gently pull the white plug from the motherboard.
Gently unplug the microphone from the motherboard using a pair of blunt tweezers.
