Salta al contenuto principale
Asus Tablet MeMO Pad 7 ME7000C Battery Replacement
Cosa ti serve
  1. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 2, immagine 1 di 3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 2, immagine 2 di 3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 2, immagine 3 di 3
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 3, immagine 1 di 2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 3, immagine 2 di 2
    • Pull the rear panel and the display screen away from each other.
  4. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: passo 4, immagine 1 di 3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: passo 4, immagine 2 di 3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  5. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 5, immagine 1 di 2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: passo 5, immagine 2 di 2
    • Remove the battery from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 599
