Salta al contenuto principale
Asus TUF Gaming FX705G Track Pad Replacement
Cosa ti serve
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: passo 1, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: passo 2, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement: passo 2, immagine 2 di 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: passo 3, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: passo 4, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement: passo 4, immagine 2 di 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: passo 5, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement, Track pad: passo 5, immagine 2 di 2
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: passo 6, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: passo 7, immagine 1 di 2 Asus TUF Gaming FX705G Track Pad Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: passo 8, immagine 1 di 3 Asus TUF Gaming FX705G Track Pad Replacement: passo 8, immagine 2 di 3 Asus TUF Gaming FX705G Track Pad Replacement: passo 8, immagine 3 di 3
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,912
