Salta al contenuto principale
Asus TUF Gaming FX705G M.2 SSD Replacement
Cosa ti serve
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: passo 1, immagine 1 di 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: passo 2, immagine 1 di 2 Asus TUF Gaming FX705G M.2 SSD Replacement: passo 2, immagine 2 di 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: passo 3, immagine 1 di 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: passo 4, immagine 1 di 2 Asus TUF Gaming FX705G M.2 SSD Replacement: passo 4, immagine 2 di 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: passo 5, immagine 1 di 1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: passo 6, immagine 1 di 1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 46
Tutti i Tempi: 4,493
