Salta al contenuto principale
Asus TUF Gaming FX705G Back Cover Replacement
Cosa ti serve
  1. Asus TUF Gaming FX705G Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Asus TUF Gaming FX705G Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Back Cover Replacement: passo 2, immagine 1 di 2 Asus TUF Gaming FX705G Back Cover Replacement: passo 2, immagine 2 di 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
Conclusione
Un commento
where can I buy fx505dy back cover replacement because mine has broken grills and stripped screw
Jakkinen Daniel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 7,977
