Salta al contenuto principale
Asus TUF Gaming FX505DY Motherboard Replacement
Cosa ti serve
  1. Asus TUF Gaming FX505DY Motherboard Replacement, Back Case: passo 1, immagine 1 di 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. Asus TUF Gaming FX505DY Motherboard Replacement: passo 2, immagine 1 di 2 Asus TUF Gaming FX505DY Motherboard Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. Asus TUF Gaming FX505DY Motherboard Replacement: passo 3, immagine 1 di 2 Asus TUF Gaming FX505DY Motherboard Replacement: passo 3, immagine 2 di 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. Asus TUF Gaming FX505DY Motherboard Replacement: passo 4, immagine 1 di 2 Asus TUF Gaming FX505DY Motherboard Replacement: passo 4, immagine 2 di 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. Asus TUF Gaming FX505DY Motherboard Replacement, Motherboard: passo 5, immagine 1 di 3 Asus TUF Gaming FX505DY Motherboard Replacement, Motherboard: passo 5, immagine 2 di 3 Asus TUF Gaming FX505DY Motherboard Replacement, Motherboard: passo 5, immagine 3 di 3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  6. Asus TUF Gaming FX505DY Motherboard Replacement: passo 6, immagine 1 di 3 Asus TUF Gaming FX505DY Motherboard Replacement: passo 6, immagine 2 di 3 Asus TUF Gaming FX505DY Motherboard Replacement: passo 6, immagine 3 di 3
    • Gently remove all power cables connecting the fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
  7. Asus TUF Gaming FX505DY Motherboard Replacement: passo 7, immagine 1 di 2 Asus TUF Gaming FX505DY Motherboard Replacement: passo 7, immagine 2 di 2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm screws.
    • Disconnect the primary connector cable located at the bottom left and carefully remove the module.
  8. Asus TUF Gaming FX505DY Motherboard Replacement: passo 8, immagine 1 di 3 Asus TUF Gaming FX505DY Motherboard Replacement: passo 8, immagine 2 di 3 Asus TUF Gaming FX505DY Motherboard Replacement: passo 8, immagine 3 di 3
    • Removing the ram, push down unto the ram and move the metal locking tabs to the side by lifting upward slightly then moving each to their outside.
    • Pull the ram out toward the angle when the ram is sticking up at an angle when released.
  9. Asus TUF Gaming FX505DY Motherboard Replacement: passo 9, immagine 1 di 2 Asus TUF Gaming FX505DY Motherboard Replacement: passo 9, immagine 2 di 2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm top screws holding the hard drive in place.
    • Pinch the top left corner with your finger and slide the harddrive out of its casing.
  10. Asus TUF Gaming FX505DY Motherboard Replacement: passo 10, immagine 1 di 2 Asus TUF Gaming FX505DY Motherboard Replacement: passo 10, immagine 2 di 2
    • With a Phillips 0-bit screwdriver, unscrew two 5.0 mm screws holding SSD down to the motherboard on the right side of the board
    • Slide module out of protective casing to remove piece.
  11. Asus TUF Gaming FX505DY Motherboard Replacement: passo 11, immagine 1 di 3 Asus TUF Gaming FX505DY Motherboard Replacement: passo 11, immagine 2 di 3 Asus TUF Gaming FX505DY Motherboard Replacement: passo 11, immagine 3 di 3
    • With a size 0 Phillips screwdriver, unscrew three center 5 mm screws securing the board in place.
    • Carefully lift the board and place in a safe area.
Conclusione
Un commento
Can I change the motherboard of my laptop? I have the model FX505DY (Ryzen 5 3550H, Radeon RX 560X, 17.3 inches). I would like to change it for the FX505DT model (Ryzen 7 3570H, GTX 1650, 17.3 inches)
Luis Nox - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 69
Tutti i Tempi: 1,325
