Salta al contenuto principale
Asus TF300T Tablet Motherboard Replacement
Cosa ti serve
  1. Asus TF300T Tablet Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Asus TF300T Tablet Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Disconnect the dock and make sure the power is turned of.
    • Use plastic opening tool to pry screen up and remove from outer casing.
    • Be gentle with the plastic opening tool when you reached the charging port as the thinner plastic could be broken easily.
  2. Asus TF300T Tablet Motherboard Replacement: passo 2, immagine 1 di 3 Asus TF300T Tablet Motherboard Replacement: passo 2, immagine 2 di 3 Asus TF300T Tablet Motherboard Replacement: passo 2, immagine 3 di 3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Motherboard Replacement: passo 3, immagine 1 di 2 Asus TF300T Tablet Motherboard Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a Phillips #00 Screwdriver to remove nine 3mm screws that is connected to the motherboard.
    • Use tweezers to remove connected part as shown in the picture.
  4. Asus TF300T Tablet Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the motherboard using the plastic opening tool gently.
Conclusione
Altre 5 persone hanno completato questa guida.
IUPUI, Team S2-G2, Wilson Summer 2017 Membro di IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,585
