Salta al contenuto principale
Asus TF300T Tablet Front Facing Camera Replacement
Cosa ti serve
  1. Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 1 di 2 Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: passo 1, immagine 2 di 2
    • Disconnect the dock and make sure the power is turned off.
    • Use plastic opening tool to pry screen up and remove the main tablet body from outer rim casing.
    • Be gentle with the plastic opening tool near charging port. The thinner plastic may break easily.
  2. Asus TF300T Tablet Front Facing Camera Replacement: passo 2, immagine 1 di 3 Asus TF300T Tablet Front Facing Camera Replacement: passo 2, immagine 2 di 3 Asus TF300T Tablet Front Facing Camera Replacement: passo 2, immagine 3 di 3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use plastic tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Front Facing Camera Replacement: passo 3, immagine 1 di 3 Asus TF300T Tablet Front Facing Camera Replacement: passo 3, immagine 2 di 3 Asus TF300T Tablet Front Facing Camera Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a Phillips #00 Screwdriver to remove the six 3mm screws that connect the upper part of the motherboard.
    • Use tweezers to remove red connecting wires. Remove the motherboard by lifting it upward.
  4. Asus TF300T Tablet Front Facing Camera Replacement: passo 4, immagine 1 di 1
    • Use tweezers to pull out the gold flap connected to the front camera.
    • Pull the disconnected gold flap to take out the camera.
Conclusione
Emma Sloan
Membro da: 05/17/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Wilson Summer 2017 Membro di IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 331
