Salta al contenuto principale
Asus S500 USB, Headphone, and SD card Port board replacement
Cosa ti serve
  1. Asus S500 USB, Headphone, and SD card Port board replacement, USB, Headphone, and SD card Ports: passo 1, immagine 1 di 1
    • Unscrew the 10 screws on the back cover
  2. Asus S500 USB, Headphone, and SD card Port board replacement: passo 2, immagine 1 di 1
    • Remove back cover (pry open along the grey/black line, they are held together by clips)
  3. Asus S500 USB, Headphone, and SD card Port board replacement: passo 3, immagine 1 di 1
    • Lift up tab and pull out the connector
    • Unscrew the 4 screws
    • Open up the screen (as you would to open up the laptop), and in doing so the metal piece will open up.
    • Jostle the ports and remove the small board.
Conclusione
Altre 5 persone hanno completato questa guida.
Isaac Lemus
Membro da: 04/29/14
232 Reputazione
1 Guida realizzata
2 Commenti
where can i buy the usb mic part?
jorg123 - Replica
I have a [newish] 14” Asus 3 [Blue Al./gold trim]. One of my grandchildren has wrecked one of the usb 3.1 sockets on the right [Output] side.
Is it possible to renew this socket? I have all the tools + mini soldering iron. I could connect the remaining one to a usb hub I suppose but it’s an expensive machine and I would rather it be repaired.
Any help/advice very much appreciated. Regards - Denis
Denis TRAYNOR - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,669
