Salta al contenuto principale
Asus Rog GL55VW-DH71 USB port Replacement
Cosa ti serve
  1. Asus Rog GL55VW-DH71 USB port Replacement, Battery: passo 1, immagine 1 di 3 Asus Rog GL55VW-DH71 USB port Replacement, Battery: passo 1, immagine 2 di 3 Asus Rog GL55VW-DH71 USB port Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Asus Rog GL55VW-DH71 USB port Replacement, Keyboard: passo 2, immagine 1 di 3 Asus Rog GL55VW-DH71 USB port Replacement, Keyboard: passo 2, immagine 2 di 3 Asus Rog GL55VW-DH71 USB port Replacement, Keyboard: passo 2, immagine 3 di 3
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
  3. Asus Rog GL55VW-DH71 USB port Replacement: passo 3, immagine 1 di 2 Asus Rog GL55VW-DH71 USB port Replacement: passo 3, immagine 2 di 2
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Asus Rog GL55VW-DH71 USB port Replacement: passo 4, immagine 1 di 3 Asus Rog GL55VW-DH71 USB port Replacement: passo 4, immagine 2 di 3 Asus Rog GL55VW-DH71 USB port Replacement: passo 4, immagine 3 di 3
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Asus Rog GL55VW-DH71 USB port Replacement, USB port: passo 5, immagine 1 di 2 Asus Rog GL55VW-DH71 USB port Replacement, USB port: passo 5, immagine 2 di 2
    • The pictures shown are taken with the motherboard removed. This is not required for the replacement of the USB module.
    • Remove the two 2.8mm Phillips #00 screws.
    • Carefully remove the ZIF connector ribbon cable from the module by lifting up on the latch and pulling the cable out.
Conclusione
Addison Thomas
Membro da: 02/14/18
1.232 Reputazione
8 Guide realizzate
USF Tampa, Team S1-G2, Nance Spring 2018 Membro di USF Tampa, Team S1-G2, Nance Spring 2018
USFT-NANCE-S18S1G2
4 Membri
8 Guide realizzate
Un commento
Where do you find a replacement module? Does it have a specific product name?
Jonathan Magnes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,825
