Salta al contenuto principale
Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement
Cosa ti serve
  1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: passo 1, immagine 1 di 2 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: passo 1, immagine 2 di 2
    • Remove the front panel.
    • This may involve one or two thumb screws depending on your case.
  2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 2, immagine 1 di 1
    • Detach the PSU cable from your graphics card.
  3. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 3, immagine 1 di 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 3, immagine 2 di 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 3, immagine 3 di 3
    • Unscrew the back panel screws to release the graphics card.
    • Release the PCIe switch.
    • Be careful when using a tool as you can damage the motherboard if the tool slips.
    • Take the graphics card out vertically.
  4. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 4, immagine 1 di 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 4, immagine 2 di 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 4, immagine 3 di 3
    • Unscrew the heat-sink screws.
    • Remove the heat-sink vertically.
    • It is important to remove it vertically as there are pins on the right side that must not be bent.
  5. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 5, immagine 1 di 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 5, immagine 2 di 3 Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: passo 5, immagine 3 di 3
    • Unscrew the small screw holding the SSD.
    • Remove the SSD at an angle.
    • Be careful to avoid grabbing the SSD from its circuit.
    • Insert a new SSD at a 30-40 degree angle.
Conclusione
Altre 7 persone hanno completato questa guida.
2 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 78
Tutti i Tempi: 3,805
