Salta al contenuto principale
Asus ROG Strix GL702VS Trackpad Replacement
Cosa ti serve
  1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Trackpad Replacement: passo 2, immagine 1 di 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Trackpad Replacement: passo 3, immagine 1 di 2 Asus ROG Strix GL702VS Trackpad Replacement: passo 3, immagine 2 di 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Trackpad Replacement: passo 4, immagine 1 di 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: passo 5, immagine 1 di 3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: passo 5, immagine 2 di 3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: passo 5, immagine 3 di 3
    • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
    • Slide the ribbon cables out of the connectors on the motherboard.
  6. Asus ROG Strix GL702VS Trackpad Replacement: passo 6, immagine 1 di 2 Asus ROG Strix GL702VS Trackpad Replacement: passo 6, immagine 2 di 2
    • Remove the covering foil holding the trackpad into place.
    • Completely peel the foil back to ensure it does not interfere with the following processes.
  7. Asus ROG Strix GL702VS Trackpad Replacement: passo 7, immagine 1 di 2 Asus ROG Strix GL702VS Trackpad Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift up speaker cable that is laying overtop using a pair of tweezers.
    • Do not to overextend the wire since you may accidently pull the wire out.
  8. Asus ROG Strix GL702VS Trackpad Replacement: passo 8, immagine 1 di 3 Asus ROG Strix GL702VS Trackpad Replacement: passo 8, immagine 2 di 3 Asus ROG Strix GL702VS Trackpad Replacement: passo 8, immagine 3 di 3
    • Remove the three 4mm JIS #0 screws that are securing the trackpad.
  9. Asus ROG Strix GL702VS Trackpad Replacement: passo 9, immagine 1 di 2 Asus ROG Strix GL702VS Trackpad Replacement: passo 9, immagine 2 di 2
    • Once freed, slide the trackpad backwards towards the center of laptop.
    • This may require some jiggling. Lifting the laptop off your working surface may help.
    • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 822
