Salta al contenuto principale
Asus ROG Strix GL702VS LCD Screen (Display) Replacement
Cosa ti serve
  1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): passo 1, immagine 1 di 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): passo 1, immagine 2 di 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): passo 1, immagine 3 di 3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
    Chiedi a FixBot
  2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 2, immagine 1 di 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 2, immagine 2 di 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 2, immagine 3 di 3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
    Chiedi a FixBot
  3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 3, immagine 1 di 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 3, immagine 2 di 2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
    Chiedi a FixBot
  4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 4, immagine 1 di 1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
    Chiedi a FixBot
  5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 5, immagine 1 di 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 5, immagine 2 di 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 5, immagine 3 di 3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
    Chiedi a FixBot
  6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 6, immagine 1 di 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: passo 6, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 5
Ultimi 30 giorni: 49
Tutti i Tempi: 2,250
