Salta al contenuto principale
Asus ROG GL551J Hard Drive Replacement
Cosa ti serve
  1. Asus ROG GL551J Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: passo 2, immagine 1 di 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 Asus ROG GL551J Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: passo 5, immagine 1 di 2 Asus ROG GL551J Hard Drive Replacement: passo 5, immagine 2 di 2
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: passo 6, immagine 1 di 2 Asus ROG GL551J Hard Drive Replacement: passo 6, immagine 2 di 2
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
Conclusione
Altre 7 persone hanno completato questa guida.
Thien Vu
Membro da: 02/15/17
412 Reputazione
2 Guide realizzate
USF Tampa, Team 5-4, Lacy Spring 2017 Membro di USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 4,684
