Salta al contenuto principale
Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement
Cosa ti serve
  1. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: passo 1, immagine 1 di 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: passo 1, immagine 2 di 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 2, immagine 1 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 2, immagine 2 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 2, immagine 3 di 3
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 3, immagine 1 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 3, immagine 2 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 3, immagine 3 di 3
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 4, immagine 1 di 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 4, immagine 2 di 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 5, immagine 1 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 5, immagine 2 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 5, immagine 3 di 3
    • Remove the screws holding the hard drives in place using a Phillips 1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 6, immagine 1 di 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 7, immagine 1 di 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 7, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 8, immagine 1 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 8, immagine 2 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 8, immagine 3 di 3
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 9, immagine 1 di 1
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 10, immagine 1 di 1
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 11, immagine 1 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 11, immagine 2 di 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 11, immagine 3 di 3
    • Use a metal spudger to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 12, immagine 1 di 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 12, immagine 2 di 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 13, immagine 1 di 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: passo 13, immagine 2 di 2
    • Use a pair of tweezers to undo each of the two ribbon connectors.
    • The Left and right button is now completely disconnected from the laptop and you can remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S8-G8, Wilson Spring 2019 Membro di IUPUI, Team S8-G8, Wilson Spring 2019
IUPUI-WILSON-S19S8G8
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,118
