Salta al contenuto principale
Asus ROG G751JL-DS71 Battery Replacement
Cosa ti serve
  1. Asus ROG G751JL-DS71 Battery Replacement, CD-ROM Player: passo 1, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, CD-ROM Player: passo 1, immagine 2 di 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
    The screw doesn't come out completely.
    Steve Menard - Replica
  2. Asus ROG G751JL-DS71 Battery Replacement: passo 2, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 2, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 2, immagine 3 di 3
    • Use the nylon spudger to remove the back center panel.
    Pull up on the rubber cover to aid the spudger.
  3. Asus ROG G751JL-DS71 Battery Replacement: passo 3, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 3, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
    Why is it necessary to remove the CD Drive?
    Judi Pillsbury - Replica
  4. Asus ROG G751JL-DS71 Battery Replacement: passo 4, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 4, immagine 2 di 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Battery Replacement, Top Rear Panel: passo 5, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, Top Rear Panel: passo 5, immagine 2 di 2
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  6. Asus ROG G751JL-DS71 Battery Replacement: passo 6, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 6, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  7. Asus ROG G751JL-DS71 Battery Replacement: passo 7, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 7, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 7, immagine 3 di 3
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  8. Asus ROG G751JL-DS71 Battery Replacement, Keyboard: passo 8, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement, Keyboard: passo 8, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement, Keyboard: passo 8, immagine 3 di 3
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
    There are 3 screws to remove on the left side as the rear of the laptop is facing you.
  9. Asus ROG G751JL-DS71 Battery Replacement: passo 9, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 9, immagine 2 di 2
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  10. Asus ROG G751JL-DS71 Battery Replacement: passo 10, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 10, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 10, immagine 3 di 3
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  11. Asus ROG G751JL-DS71 Battery Replacement: passo 11, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 11, immagine 2 di 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
    ON STEP 11
    Do not just pull the ribbons out! locate the grey bar on the connectors and lift them gently from the ribbon side upward, they will open and the ribbons will come away easily, replace the ribbons by putting them in place and clicking down the grey bars to lock them in.
    Off Duty Pastor - Replica
    Crud!! I didn't see your comment in time, Pastor! I am not accustomed to ribbon connectors. I found out too late, after severing one, that they each have “clips” locking them in place. This battery replacement just became complicated.
    This is the keyboard panel removal. What about removing the keyboard from the keyboard panel?
    tech cowboy - Replica
  12. Asus ROG G751JL-DS71 Battery Replacement, Monitor: passo 12, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, Monitor: passo 12, immagine 2 di 2
    • Use a pair of tweezers to carefully disconnect the pin connector.
    ON STEP 12
    BEWARE The guidance and second photo here is for the battery connector!!
    DO NOT REMOVE MONITOR UNTIL YOU HAVE DISCONNECTED THE BLACK AND WHITE CABLES ON THE LEFT SIDE OF THE LEFT HINGE (Lift then off gently with tweezers) AND THE FLAT CONNECTOR ON THE RIGHT SIDE OF THE RIGHT HINGE! (There is a strap for you to gently pull on!)
    I have a red and yellow wires that i have no idea were they go they are coming out of the monitor
    Eugene Nelson - Replica
    I have a red and a blue wire coming from my monitor I have no idea where they go there's nothing in the instructions that said anything about them anyone have any thoughts
  13. Asus ROG G751JL-DS71 Battery Replacement: passo 13, immagine 1 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 13, immagine 2 di 3 Asus ROG G751JL-DS71 Battery Replacement: passo 13, immagine 3 di 3
    • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
    • The monitor is now free to be completely lifted off the laptop.
    I had 3 screws on either side.
  14. Asus ROG G751JL-DS71 Battery Replacement, Battery: passo 14, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement, Battery: passo 14, immagine 2 di 2
    • Disconnect the pin connector that attaches the battery to the motherboard.
    • Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
  15. Asus ROG G751JL-DS71 Battery Replacement: passo 15, immagine 1 di 2 Asus ROG G751JL-DS71 Battery Replacement: passo 15, immagine 2 di 2
    • The battery can now be lifted away from the laptop.
Conclusione
Altre 7 persone hanno completato questa guida.
Aurora Rios
Membro da: 01/22/18
917 Reputazione
4 Guide realizzate
Cal Poly, Team S16-G1, Banghart Winter 2018 Membro di Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 Membri
22 Guide realizzate
3 Commenti
Can yo please share the review of this battery? Should I go for original battery or ifixit battery?
Chintan Goyal - Replica
Thank you so much for this Aurora it really helped me work on my ROG, hope my extra notes on Section 11 & 12 help others! Blessings!
I have a G751JT-CH71 & I'm not sure if the models are slightly different but I cannot remove the battery by simply lifting it out of the compartment. The battery has 4 lock-in tabs towards the back of the laptop AND 2 additional tabs that are beneath the board. I'm going to carefully pry the battery out, but I'm unsure if there's a recommended method to prying the battery out…
Daniel Sierra - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 65
Tutti i Tempi: 5,592
