Salta al contenuto principale
Asus ROG G751JL-BSI7T28 Display Assembly Replacement
Cosa ti serve
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: passo 1, immagine 1 di 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 2, immagine 1 di 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 2, immagine 2 di 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 2, immagine 3 di 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: passo 3, immagine 1 di 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: passo 3, immagine 2 di 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 4, immagine 1 di 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 4, immagine 2 di 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 5, immagine 1 di 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 5, immagine 2 di 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 5, immagine 3 di 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 6, immagine 1 di 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 6, immagine 2 di 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 6, immagine 3 di 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 7, immagine 1 di 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: passo 7, immagine 2 di 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
81.748 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.767 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 339
