Salta al contenuto principale
Asus ROG G751JL-BB17T29 Keyboard Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Asus ROG G751JL-BB17T29 Keyboard Replacement, Remove the RAM access door: passo 1, immagine 1 di 2 Asus ROG G751JL-BB17T29 Keyboard Replacement, Remove the RAM access door: passo 1, immagine 2 di 2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 3, immagine 1 di 2 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 3, immagine 2 di 2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 4, immagine 1 di 3 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 4, immagine 2 di 3 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 4, immagine 3 di 3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the RAM access door.
  6. Asus ROG G751JL-BB17T29 Keyboard Replacement, Remove the optical drive: passo 6, immagine 1 di 1
    • Remove the 5.2 mm Phillips #00 screw securing the optical drive.
  7. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 7, immagine 1 di 3 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 7, immagine 2 di 3 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 7, immagine 3 di 3
    • Insert an opening tool into the gap between the optical drive and the laptop.
    • Pry the optical drive straight out of the laptop.
    • Remove the optical drive.
  8. Asus ROG G751JL-BB17T29 Keyboard Replacement, Keyboard: passo 8, immagine 1 di 3 Asus ROG G751JL-BB17T29 Keyboard Replacement, Keyboard: passo 8, immagine 2 di 3 Asus ROG G751JL-BB17T29 Keyboard Replacement, Keyboard: passo 8, immagine 3 di 3
    • Remove the ten 5.2 mm screws holding the main panel in place, highlighted in the photo, with a Phillips screwdriver.
    • Remove the four 5.2 mm screws underneath the center panel, highlighted in the photo, with a Phillips screwdriver.
  9. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 9, immagine 1 di 2 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 9, immagine 2 di 2
    • Remove the two 6.8 mm screws underneath to back panel, highlighted in the photo, with a Phillips screwdriver.
  10. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 10, immagine 1 di 2 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 10, immagine 2 di 2
    • Use the plastic opening tool to pry the keyboard from the base of the laptop.
  11. Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 11, immagine 1 di 2 Asus ROG G751JL-BB17T29 Keyboard Replacement: passo 11, immagine 2 di 2
    • Lift the keyboard carefully, otherwise the ribbon connectors may tear or break
    • Unlatch and disconnect each of the four ZIF connectors.
    • The keyboard is now fully disconnected and you are now free to lift the keyboard away from the computer.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 2-1, Sullivan Fall 2016 Membro di USF Tampa, Team 2-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G1
4 Membri
20 Guide realizzate
Un commento
Great work, but you are missing the last few steps of the replacement as all you are showing is how to remove the upper assembly
James Barlow-Jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,609
