Salta al contenuto principale
Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
Cosa ti serve
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: passo 1, immagine 1 di 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: passo 1, immagine 2 di 2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 2, immagine 1 di 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 2, immagine 2 di 2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 3, immagine 1 di 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 3, immagine 2 di 2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 4, immagine 1 di 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 4, immagine 2 di 2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 5, immagine 1 di 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 5, immagine 2 di 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 5, immagine 3 di 3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 6, immagine 1 di 1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 394
