Salta al contenuto principale
Asus ROG G750JM-BS17N23 Hard Drive Replacement
Cosa ti serve
  1. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Back Plate: passo 1, immagine 1 di 1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  3. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 3, immagine 1 di 3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 3, immagine 2 di 3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  4. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • To access the hard drive, remove the back plate.
  5. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 5, immagine 1 di 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the three 4mm Phillips #2 screws.
  6. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 6, immagine 1 di 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
  7. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 7, immagine 1 di 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 7, immagine 2 di 2
    • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 479
