Salta al contenuto principale
Asus ROG G750JH-DB71 Hard Drive Replacement
Cosa ti serve
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: passo 2, immagine 1 di 3 Asus ROG G750JH-DB71 Hard Drive Replacement: passo 2, immagine 2 di 3 Asus ROG G750JH-DB71 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: passo 4, immagine 1 di 3 Asus ROG G750JH-DB71 Hard Drive Replacement: passo 4, immagine 2 di 3 Asus ROG G750JH-DB71 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 130
