Introduzione
This guide covers how to replace the fan for the Asus ROG G750JH-DB71.
The fan provides cooling for all the internal components. After long term use of the laptop the components start to heat up. The fan will turn on a remove heat from inside the laptop. If your laptop is experiencing overheating after extended use, consider replacing the fan.
Before replacing the fan, inspect it, look to see if there's any buildup of dust or debris keeping the fan from working. If this is the case clean the fan with a cloth, cotton swab, or whatever you prefer. Make sure to also check the vents on the exterior of the laptop for any dust or debris.
Cosa ti serve
Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
Remove all of the plastic caps around the edges using a pick or flathead screwdriver, and remove the screws underneath them. (one 13 mm Phillips #00, six 8 mm Phillips #00)
Remove the remaining screws underneath the cover . (six 8mm Phillips #00, three 1 mm Phillips #00)
