Salta al contenuto principale
Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
Cosa ti serve
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: passo 1, immagine 1 di 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: passo 1, immagine 2 di 3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: passo 1, immagine 3 di 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: passo 2, immagine 1 di 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: passo 2, immagine 2 di 2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 3, immagine 1 di 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 3, immagine 2 di 2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 4, immagine 1 di 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 5, immagine 1 di 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 5, immagine 2 di 2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 6, immagine 1 di 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 6, immagine 2 di 2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 7, immagine 1 di 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: passo 7, immagine 2 di 2
    • Remove the two Phillips head screws holding the buttons in place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 370
