Salta al contenuto principale
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
Cosa ti serve
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: passo 1, immagine 1 di 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: passo 1, immagine 2 di 2
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: passo 2, immagine 1 di 1
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: passo 3, immagine 1 di 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: passo 3, immagine 2 di 2
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 232
