Salta al contenuto principale
Asus ROG G74SX-DH73-3D Battery Replacement
Cosa ti serve
  1. Asus ROG G74SX-DH73-3D Battery Replacement, Battery: passo 1, immagine 1 di 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: passo 1, immagine 2 di 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: passo 1, immagine 3 di 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
Conclusione
2 Commenti
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - Replica
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 353
