Salta al contenuto principale
Asus ROG G56JK CD Drive Replacement
Cosa ti serve
  1. Asus ROG G56JK CD Drive Replacement, Battery: passo 1, immagine 1 di 2 Asus ROG G56JK CD Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK CD Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK CD Drive Replacement: passo 3, immagine 1 di 1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK CD Drive Replacement, Back Panel: passo 4, immagine 1 di 1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK CD Drive Replacement: passo 5, immagine 1 di 1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK CD Drive Replacement, CD Drive: passo 6, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the four 4mm screws.
  7. Asus ROG G56JK CD Drive Replacement: passo 7, immagine 1 di 1
    • Gently pull the CD drive out of the side of the laptop and remove it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 15
Tutti i Tempi: 718
