Salta al contenuto principale
Asus ROG G53SW-XT1 Optical Drive Replacement
Cosa ti serve
  1. Asus ROG G53SW-XT1 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Optical Drive Replacement: passo 3, immagine 1 di 2 Asus ROG G53SW-XT1 Optical Drive Replacement: passo 3, immagine 2 di 2
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: passo 4, immagine 1 di 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: passo 4, immagine 2 di 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: passo 4, immagine 3 di 3
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Optical Drive Replacement: passo 5, immagine 1 di 3 Asus ROG G53SW-XT1 Optical Drive Replacement: passo 5, immagine 2 di 3 Asus ROG G53SW-XT1 Optical Drive Replacement: passo 5, immagine 3 di 3
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: passo 6, immagine 1 di 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: passo 6, immagine 2 di 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: passo 6, immagine 3 di 3
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Optical Drive Replacement: passo 7, immagine 1 di 1
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Optical Drive Replacement: passo 8, immagine 1 di 2 Asus ROG G53SW-XT1 Optical Drive Replacement: passo 8, immagine 2 di 2
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Optical Drive Replacement, Optical Drive: passo 9, immagine 1 di 1
    • Remove the single 7mm Phillips #0 screw holding the hard drive in place.
  10. Asus ROG G53SW-XT1 Optical Drive Replacement: passo 10, immagine 1 di 2 Asus ROG G53SW-XT1 Optical Drive Replacement: passo 10, immagine 2 di 2
    • Slide the hard drive out of the casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 220
