Salta al contenuto principale
Asus ROG G53SW-XT1 Hard Drive Replacement
Cosa ti serve
  1. Asus ROG G53SW-XT1 Hard Drive  Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 2, immagine 1 di 1
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 3, immagine 1 di 2 Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 3, immagine 2 di 2
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Hard Drive  Replacement, Keyboard: passo 4, immagine 1 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Keyboard: passo 4, immagine 2 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Keyboard: passo 4, immagine 3 di 3
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 5, immagine 1 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 5, immagine 2 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 5, immagine 3 di 3
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Hard Drive  Replacement, Back Panel: passo 6, immagine 1 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Back Panel: passo 6, immagine 2 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement, Back Panel: passo 6, immagine 3 di 3
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 7, immagine 1 di 1
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 8, immagine 1 di 2 Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 8, immagine 2 di 2
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Hard Drive  Replacement, Hard Drive: passo 9, immagine 1 di 2 Asus ROG G53SW-XT1 Hard Drive  Replacement, Hard Drive: passo 9, immagine 2 di 2
    • Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
  10. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 10, immagine 1 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 10, immagine 2 di 3 Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 10, immagine 3 di 3
    • Remove the Hard Drive and case from the laptop.
    • Remove the four Phillips #0 screws from the hard drive case.
  11. Asus ROG G53SW-XT1 Hard Drive  Replacement: passo 11, immagine 1 di 1
    • Slide the hard drive out of the casing.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Bottom cover holds only by 9 screws. You don’t need to remove 14 screws. All screws at the bottom with M2 5x7 label (do not remove two small screws. And one scre on the right in the middle without number on the metal plate). You don’t need to remove screw with M2 5x7 label on the right side, second from the corner.
John McCain - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,072
