Salta al contenuto principale
Asus ROG Ally Heatsink Replacement
Cosa ti serve
  1. Asus ROG Ally Heatsink Replacement, Prepare your device for disassembly: passo 1, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Prepare your device for disassembly: passo 1, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Prepare your device for disassembly: passo 1, immagine 3 di 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally Heatsink Replacement, Unfasten the back cover: passo 2, immagine 1 di 2 Asus ROG Ally Heatsink Replacement, Unfasten the back cover: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $31.41
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally Heatsink Replacement, Insert an opening pick: passo 3, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Insert an opening pick: passo 3, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Insert an opening pick: passo 3, immagine 3 di 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally Heatsink Replacement, Release the back cover's clips: passo 4, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Release the back cover's clips: passo 4, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Release the back cover's clips: passo 4, immagine 3 di 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally Heatsink Replacement, Remove the back cover: passo 5, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Remove the back cover: passo 5, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Remove the back cover: passo 5, immagine 3 di 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally Heatsink Replacement, Remove the plastic cover: passo 6, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Remove the plastic cover: passo 6, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Remove the plastic cover: passo 6, immagine 3 di 3
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally Heatsink Replacement, Unlatch the locking bar: passo 7, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Unlatch the locking bar: passo 7, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Unlatch the locking bar: passo 7, immagine 3 di 3
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally Heatsink Replacement, Disconnect the battery: passo 8, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Disconnect the battery: passo 8, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Disconnect the battery: passo 8, immagine 3 di 3
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally Heatsink Replacement, Separate the fan tape: passo 9, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Separate the fan tape: passo 9, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Separate the fan tape: passo 9, immagine 3 di 3
    • Two pieces of tape secure the upper edges of the fans to the heatsink foam.
    • Insert the point of a spudger between the tape on the upper edge of one of the fans and the heatsink foam.
    • Slide the spudger under the length of the tape to separate it from the foam.
  10. Asus ROG Ally Heatsink Replacement: passo 10, immagine 1 di 3 Asus ROG Ally Heatsink Replacement: passo 10, immagine 2 di 3 Asus ROG Ally Heatsink Replacement: passo 10, immagine 3 di 3
    • Repeat the previous step to separate the other piece of fan tape.
    • During reassembly, firmly press both pieces of tape back onto the foam.
  11. Asus ROG Ally Heatsink Replacement, Unfasten the heatsink: passo 11, immagine 1 di 2 Asus ROG Ally Heatsink Replacement, Unfasten the heatsink: passo 11, immagine 2 di 2
    • Use a Phillips #0 screwdriver to fully loosen the four captive screws securing the heatsink. Don't try to remove these screws.
    • The bottom left screw has a warning sticker on it. Pierce through it with your screwdriver or use tweezers to remove it.
    • During reassembly, tighten the screws in order (1, 2, 3, 4) based on the number stamped next to each screw.
  12. Asus ROG Ally Heatsink Replacement, Remove the heatsink: passo 12, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Remove the heatsink: passo 12, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Remove the heatsink: passo 12, immagine 3 di 3
    • Lift the bottom edge of the heatsink and remove it.
    • You may feel some resistance, as thermal paste bonds the heatsink to the CPU.
  13. Asus ROG Ally Heatsink Replacement, Replace the thermal paste: passo 13, immagine 1 di 3 Asus ROG Ally Heatsink Replacement, Replace the thermal paste: passo 13, immagine 2 di 3 Asus ROG Ally Heatsink Replacement, Replace the thermal paste: passo 13, immagine 3 di 3
    • Before installing a heatsink, follow this guide to clean both the CPU and heatsink and apply new thermal paste.
Conclusione
Altre 2 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
119.085 Reputazione
838 Guide realizzate
iFixit Membro di iFixit
Staff
119 Membri
21.724 Guide realizzate
1Commento della guida
What kind of Thermal Paste does ROG Ally use? Just normal thermal paste or some kind of phase-change thermal pad?
Rizky Saputra - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 168
Tutti i Tempi: 2,021
