Salta al contenuto principale
Asus R541UA-RB51 CD Drive Replacement
Cosa ti serve
  1. Asus R541UA-RB51 CD Drive Replacement, Keyboard: passo 1, immagine 1 di 3 Asus R541UA-RB51 CD Drive Replacement, Keyboard: passo 1, immagine 2 di 3 Asus R541UA-RB51 CD Drive Replacement, Keyboard: passo 1, immagine 3 di 3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 CD Drive Replacement: passo 2, immagine 1 di 2 Asus R541UA-RB51 CD Drive Replacement: passo 2, immagine 2 di 2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 CD Drive Replacement: passo 3, immagine 1 di 2 Asus R541UA-RB51 CD Drive Replacement: passo 3, immagine 2 di 2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 CD Drive Replacement, CD Drive: passo 4, immagine 1 di 1
    • Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
  5. Asus R541UA-RB51 CD Drive Replacement: passo 5, immagine 1 di 2 Asus R541UA-RB51 CD Drive Replacement: passo 5, immagine 2 di 2
    • Gently slide the CD drive away and pull up to remove it from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 300
