Salta al contenuto principale
Asus R541U Laptop Hard Drive Replacement
Cosa ti serve
  1. Asus R541U Laptop Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the ten screws from the back cover.
  2. Asus R541U Laptop Hard Drive Replacement: passo 2, immagine 1 di 2 Asus R541U Laptop Hard Drive Replacement: passo 2, immagine 2 di 2
    • Flip the laptop over and open the case.
    • Use a plastic opening pick or card to pry at the seams between the plastic palm rests and the back cover.
    • The edges will ordinarily be the easiest places to start.
    • Pry all around the case to release the plastic clips, but do not completely remove the palm rest as there are still cables connecting it to the case.
  3. Asus R541U Laptop Hard Drive Replacement: passo 3, immagine 1 di 1
    • Using a spudger, gently pry open the locking mechanism on ZIF connectors connecting the keyboard and trackpad cables to the motherboard.
    • Once the locking tabs have been flipped up, slide the cables out from the connectors.
    • Remove the keyboard assembly.
  4. Asus R541U Laptop Hard Drive Replacement: passo 4, immagine 1 di 2 Asus R541U Laptop Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove the two screws holding the storage drive enclosure in place using a Phillips #0 screwdriver.
    • Use the lip of the enclosure to lightly pull the hard drive to the right, disengaging it from the rest of the computer.
    • Make note of the orientation of the connection pieces. It will be helpful while installing your replacement.
  5. Asus R541U Laptop Hard Drive Replacement: passo 5, immagine 1 di 2 Asus R541U Laptop Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the four screws securing the hard drive to the enclosure with a Phillips #0 screwdriver.
    • Gently remove the drive from the enclosure.
  6. Asus R541U Laptop Hard Drive Replacement: passo 6, immagine 1 di 3 Asus R541U Laptop Hard Drive Replacement: passo 6, immagine 2 di 3 Asus R541U Laptop Hard Drive Replacement: passo 6, immagine 3 di 3
    • Insert your new storage drive (Solid State Drive shown here) into the enclosure and secure it with the screws used previously.
    • Make sure that the connector piece for the new storage drive will face the correct way and match up with the connectors on the laptop in the same way the original drive did.
    • Insert the drive into the bay and slide it to the left to reconnect it to the motherboard.
    • Replace the two screws to hold the enclosure in place using a Phillips #0 screwdriver.
Conclusione
Un commento
My Asus cant show my hard drive on BIOS menu
Siyabonga Dankie Mbutho - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 60
Tutti i Tempi: 2,953
