Introduzione
In the event of system errors in crashes, your hard drive may be damaged or corrupted. Using a 1.5mm flathead screwdriver, you can quickly remove and replace this device's hard drive. It is fairly small and compact, so this particular guide should not take you longer than five minutes.
Strumenti
Ricambi
Nessuna parte specificata.
Remove the bottom left and right 12.7mm screws using a JIS 00 screwdriver.
Quasi finito!
Conclusione
