Introduzione
Many times your optical drive can fail due to mechanical issues due physical contact or damage, heat, humidity, dust, power surges, or even time. If you have a failing optical drive, your laptop will have issues reading or writing data on an optical disk such as CDs and DVDs. This guide walks you through replacing the optical drive on an Asus R510CA-OB01.
Before beginning the guide, make sure that the device is completely powered off and disconnected from the charger.
Cosa ti serve
Shut down the computer and disconnect all external devices connected to it.
Turn the computers that it is upside down. Position the computer with the front towards you.
Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
Remove the three 2mm silver screws using a Phillips #000 bit.
Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
With your hands, gently slide the optical drive out of the laptop.
