Salta al contenuto principale
Asus R510CA-OB01 Optical Drive Replacement
Cosa ti serve
  1. Asus R510CA-OB01 Optical Drive Replacement, Keyboard and Mousepad: passo 1, immagine 1 di 1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  2. Asus R510CA-OB01 Optical Drive Replacement: passo 2, immagine 1 di 1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  3. Asus R510CA-OB01 Optical Drive Replacement: passo 3, immagine 1 di 2 Asus R510CA-OB01 Optical Drive Replacement: passo 3, immagine 2 di 2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  4. Asus R510CA-OB01 Optical Drive Replacement: passo 4, immagine 1 di 3 Asus R510CA-OB01 Optical Drive Replacement: passo 4, immagine 2 di 3 Asus R510CA-OB01 Optical Drive Replacement: passo 4, immagine 3 di 3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  5. Asus R510CA-OB01 Optical Drive Replacement: passo 5, immagine 1 di 2 Asus R510CA-OB01 Optical Drive Replacement: passo 5, immagine 2 di 2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  6. Asus R510CA-OB01 Optical Drive Replacement: passo 6, immagine 1 di 2 Asus R510CA-OB01 Optical Drive Replacement: passo 6, immagine 2 di 2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  7. Asus R510CA-OB01 Optical Drive Replacement: passo 7, immagine 1 di 2 Asus R510CA-OB01 Optical Drive Replacement: passo 7, immagine 2 di 2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  8. Asus R510CA-OB01 Optical Drive Replacement: passo 8, immagine 1 di 3 Asus R510CA-OB01 Optical Drive Replacement: passo 8, immagine 2 di 3 Asus R510CA-OB01 Optical Drive Replacement: passo 8, immagine 3 di 3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  9. Asus R510CA-OB01 Optical Drive Replacement: passo 9, immagine 1 di 2 Asus R510CA-OB01 Optical Drive Replacement: passo 9, immagine 2 di 2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
  10. Asus R510CA-OB01 Optical Drive Replacement, Optical Drive: passo 10, immagine 1 di 2 Asus R510CA-OB01 Optical Drive Replacement, Optical Drive: passo 10, immagine 2 di 2
    • Remove the 4.5mm silver screw in the top right corner using a Phillips #0 bit.
    • Remove the three 2mm silver screws using a Phillips #000 bit.
    • Remove the 5mm screw using a Phillips #1 bit that is holding the optical drive in place.
    • With your hands, gently slide the optical drive out of the laptop.
Conclusione
Mame
Membro da: 03/25/19
13 Reputazione
2 Guide realizzate
IUPUI, Team S1-G2, Henning Spring 2019 Membro di IUPUI, Team S1-G2, Henning Spring 2019
IUPUI-HENNING-S19S1G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 258
