Salta al contenuto principale
Asus Q552UB-BHI7T12 RAM Replacement
  1. Asus Q552UB-BHI7T12 RAM Replacement, RAM: passo 1, immagine 1 di 2 Asus Q552UB-BHI7T12 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • On the bottom of the laptop, gently pull the wire connecting the battery to the motherboard
  2. Asus Q552UB-BHI7T12 RAM Replacement: passo 2, immagine 1 di 1
    • Gently lever the two arms securing the RAM toward either side of the laptop, while holding the RAM in place with your thumbs.
  3. Asus Q552UB-BHI7T12 RAM Replacement: passo 3, immagine 1 di 1
    • Carefully slide the ram with your index fingers from in between the white tabs.
Conclusione
To reassemble device, follow the instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 872
