Salta al contenuto principale
Asus Q552UB-BHI7T12 MotherBoard Replacement
Cosa ti serve
  1. Asus Q552UB-BHI7T12 MotherBoard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 2, immagine 1 di 2 Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 2, immagine 2 di 2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 3, immagine 1 di 1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 4, immagine 1 di 1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
  5. Asus Q552UB-BHI7T12 MotherBoard Replacement, MotherBoard: passo 5, immagine 1 di 1
    • Next you will be removing the cpu fan. Begin by removing the nine screws holding it in place.
  6. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 6, immagine 1 di 2 Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 6, immagine 2 di 2
    • Then unplug the cable connecting into the motherboard.
    • Right next to the wire that was just unplugged, pull up and release the final clip attaching the fan to the motherboard.
    • Finally lift up and place aside.
  7. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 7, immagine 1 di 3 Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 7, immagine 2 di 3 Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 7, immagine 3 di 3
    • Next remove the screws at the top and bottom of the motherboard.
  8. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 8, immagine 1 di 2 Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 8, immagine 2 di 2
    • Underneath the battery are 3 cables plugging into the motherboard, 1 wide one and two small ones. Lift the white tabs above them up, and then slide them out.
  9. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 9, immagine 1 di 1
    • Next you will need to remove the disk drive. You can follow our guide here.
  10. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 10, immagine 1 di 1
    • Move to the top of the motherboard and unplug the two cables that are connected.
  11. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 11, immagine 1 di 1
    • Move to the bottom of the motherboard and unplug the single cable near the battery.
  12. Asus Q552UB-BHI7T12 MotherBoard Replacement: passo 12, immagine 1 di 1
    • Now slide the motherboard back toward where the disk drive was, lift up and turn over. You will see a cable connected to the bottom of the board. Pull back on the dark plastic frame and then remove the cable.
    • Set the old motherboard aside and follow the steps in reverse to install the new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,445
