Salta al contenuto principale
Asus Q551L Repair Optical Drive Replacement
Cosa ti serve
  1. Asus Q551L Repair Optical Drive Replacement, Back Panel: passo 1, immagine 1 di 2 Asus Q551L Repair Optical Drive Replacement, Back Panel: passo 1, immagine 2 di 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Optical Drive Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 680
