Salta al contenuto principale
Asus Q551L Repair Motherboard Replacement
Cosa ti serve
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: passo 1, immagine 1 di 2 Asus Q551L Repair Motherboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: passo 3, immagine 1 di 2 Asus Q551L Repair Motherboard Replacement, Battery: passo 3, immagine 2 di 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: passo 4, immagine 1 di 2 Asus Q551L Repair Motherboard Replacement: passo 4, immagine 2 di 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive: passo 5, immagine 1 di 3 Asus Q551L Repair Motherboard Replacement, Optical Drive: passo 5, immagine 2 di 3 Asus Q551L Repair Motherboard Replacement, Optical Drive: passo 5, immagine 3 di 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Asus Q551L Repair Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Asus Q551L Repair Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: passo 7, immagine 1 di 2 Asus Q551L Repair Motherboard Replacement: passo 7, immagine 2 di 2
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: passo 8, immagine 1 di 3 Asus Q551L Repair Motherboard Replacement: passo 8, immagine 2 di 3 Asus Q551L Repair Motherboard Replacement: passo 8, immagine 3 di 3
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,397
