Introduzione
This guide will show you how to replace the motherboard in an ASUS Q550LF-BBI7T07 laptop. The motherboard is the main backbone of the computer as it ties all the computer components together. Without this component, none of the computer parts such as the CPU, GPU, or hard drive can work.
Cosa ti serve
Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
Remove the ten screws surrounding the fan and cooling assembly using a Phillips #0 screwdriver.
Remove the two silver 5 mm Phillips head screws that hold the fan in place.
Remove the eight black 4 mm Phillips head screws that hold the fan in place.
