Salta al contenuto principale
Asus Q534U Motherboard Replacement
Cosa ti serve
  1. Asus Q534U Motherboard Replacement, Back Case: passo 1, immagine 1 di 3 Asus Q534U Motherboard Replacement, Back Case: passo 1, immagine 2 di 3 Asus Q534U Motherboard Replacement, Back Case: passo 1, immagine 3 di 3
    • Remove ten screws with the T5 driver.
    • Use the opening tool to carefully pry off the back case.
  2. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: passo 2, immagine 1 di 2 Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: passo 2, immagine 2 di 2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  3. Asus Q534U Motherboard Replacement: passo 3, immagine 1 di 2 Asus Q534U Motherboard Replacement: passo 3, immagine 2 di 2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
  4. Asus Q534U Motherboard Replacement, Hard Drive: passo 4, immagine 1 di 2 Asus Q534U Motherboard Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Remove four screws with the Phillips #00 screwdriver.
  5. Asus Q534U Motherboard Replacement: passo 5, immagine 1 di 2 Asus Q534U Motherboard Replacement: passo 5, immagine 2 di 2
    • Gently lift the hard disk out using the black tab.
  6. Asus Q534U Motherboard Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver remove the four screws of the metal casing
    • Remove the hard disk from the metal casing
  7. Asus Q534U Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Asus Q534U Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Asus Q534U Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    • Disconnect the four marked cables connectors at the sockets.
  8. Asus Q534U Motherboard Replacement: passo 8, immagine 1 di 3 Asus Q534U Motherboard Replacement: passo 8, immagine 2 di 3 Asus Q534U Motherboard Replacement: passo 8, immagine 3 di 3
    • Lift the connecting ports up prior to removing the connectors.
  9. Asus Q534U Motherboard Replacement: passo 9, immagine 1 di 3 Asus Q534U Motherboard Replacement: passo 9, immagine 2 di 3 Asus Q534U Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the screws holding the hinges down on both sides of the device.
    • A pry tool might be needed to lift the hinge.
  10. Asus Q534U Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove nine, 3.2 mm screws to fully release motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Jacob Pauker
Membro da: 09/03/19
228 Reputazione
2 Guide realizzate
IUPUI, Team S1-G9, Hovde Fall 2019 Membro di IUPUI, Team S1-G9, Hovde Fall 2019
IUPUI-HOVDE-F19S1G9
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,946
